Printing and Plotting
Active Contributor
pstarkey
Message 1 of 14 (397 Views)
pdf publish options ignored
397 Views, 13 Replies
05-31-2011 06:44 AM
I am using Autocad 2010, and have upgraded to windows 7.  When I publish to pdf using Dwg to Pdf.pc3, my options (single-sheet file, do not include layers, etc.) are ignored and I always get multi-sheet files with layer information included regardless of what options I select.  Is this a known issue or am I missing something?
Thanks in advance for your help.
pendean
Message 2 of 14 (395 Views)
Re: pdf publish options ignored
05-31-2011 07:08 AM in reply to: pstarkey
PUBLISHCOLLATE variable setting perhaps?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
ckako301
Message 3 of 14 (271 Views)
04-11-2013 09:03 AM in reply to: pendean
I have the same issue. I am using AutoCAD 2001 with Windows 7 - the PUBLISHCOLLATE is set to 1 and I still get multiple PDF files no matter what I select. I use single-sheet and multiple-sheet and get the same result.
Christina
pendean
Message 4 of 14 (268 Views)
04-11-2013 09:21 AM in reply to: ckako301
Do you mean AutoCAD 2011?
Are you using the PUBLISH command's default PDF option? If you select teh default DWF option as a test, does the same problem occur?
Active Contributor
ckako301
Message 5 of 14 (265 Views)
04-11-2013 09:31 AM in reply to: pendean
Oops. Typo. Yep. 2011 :smileyhappy:
I am using the publish command... I'm afraid I'm not sure what you mean by the default PDF option. I am utilizing the DWGtoPDF.pc3.
Christina
Active Contributor
ckako301
Message 6 of 14 (260 Views)
04-11-2013 09:55 AM in reply to: ckako301
I see where the option is now! If I publish to PDF instead of the "plotter named in page setup". I tried it with the PDF setting and it still creates multiple PDF files.
Christina
pendean
Message 7 of 14 (255 Views)
04-11-2013 10:05 AM in reply to: ckako301
Can youn provide screenshots of the PUBLISH command main pop-up, plus a screenshot of the pop-up after you click the Publish Options button?
Active Contributor
ckako301
Message 8 of 14 (252 Views)
04-11-2013 10:41 AM in reply to: pendean
Hopefully these help :smileyhappy:
Active Contributor
ckako301
Message 9 of 14 (248 Views)
04-11-2013 10:43 AM in reply to: ckako301
Forgot one...
pendean
Message 10 of 14 (233 Views)
04-12-2013 07:00 AM in reply to: ckako301
You can't use "PLOTTER NAMED IN PAGESETUP", it must only be PDF or DWF if you want the "one file output" to happen.
Your choice of plotter makes no difference, if you want one file output you have to do it the PUBLISH command way and not your way.
Try that, then report back.
You are not logged in.
Ask the Community
