• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    pdf plots to a different scale
    1539 Views, 5 Replies
    05-31-2010 07:38 AM
    Hi everyone,
    I'm having issues when plotting to .pdf - the .pdfs always turn out in a smaller scale than that on my paper space. I've only been using AutoCad for a few months so am a bit clueless as to why this is happening?
    For example, the scale on paperspace is set 1/2" = 1'0" and when I print directly from paperspace it comes out to scale. Yes when I plot to a .pdf it seems to make it slightly smaller??
    File is attached.
    Any ideas?
    Thanks!
    Lydia
    Please use plain text.
    *Dave Jones
    Re: pdf plots to a different scale
    05-31-2010 08:26 AM in reply to: lydiageerlings
    On 5/31/2010 7:38 AM, lydiageerlings wrote:
    > Hi everyone,
    > File is attached.
    > Any ideas?
    > Thanks!
    > Lydia
    Hi Lydia,
    how are you plotting to PDF? And what version of Acad are you using? I
    know that in the later versions of Acad that have the DWG To PDF.pc3
    file you should Plot to Layout and set your Plot Scale to 1:1 in the
    Plot dialog. I've been plotting to scale out of Acad for years so
    regardless of what version you have there's a way to do it
    Dave - DDP
    Acad 2011 and Revit 2011
    Win 7 Pro 64 bit
    Intel I7-860 @2.8GHz
    12GB DDR3 RAM
    GeForce GTX260
    05-31-2010 10:21 AM in reply to: lydiageerlings
    Hi Dave,
    Thanks for responding so quickly! I am using AutoCad LT 2010, and plotting using the DWG to PDF.pc3 function. The scale is set to 1:1, yet it is definitely printing it at a slightly smaller scale.
    I have two sheets printed, one directly from the Paperspace which is exactly to scale, and one from the resulting .pdf which, when I hold it over the other sheet, is definitely smaller.
    Does yours print exactly to scale when plotted to a .pdf??
    Cheers,
    Lydia
    *Dave Jones
    05-31-2010 11:24 AM in reply to: lydiageerlings
    On 5/31/2010 10:21 AM, lydiageerlings wrote:
    > Hi Dave,
    > Cheers,
    > Lydia
    Try plotting a 6" square in the middle of your layout with no other
    objects in the layout (titleblocks, etc) then do the overlay. Your
    problem may be a margins issue. My pdfs plot to scale but everytime the
    driver and resultant pc3 file changes I have to futz around with the
    titleblock border to get it back to 1:1.
    Dave - DDP
    Win 7 Pro 64 bit
    12GB DDR3 RAM
    GeForce GTX260
    *R.K. McSwain
    05-31-2010 03:17 PM in reply to: lydiageerlings
    Are you sure the PDF is not to scale or the "print OF the PDF" is not
    to scale?
    By default, Acrobat Reader (and probably other PDF viewers)
    automatically try to "scale to fit" the PDF to a paper size with
    margins which has the effect of shrinking the PDF.
    In general, printing to PDF is no different that printing to any other
    type of plot file (DWF, PLT), so there is nothing "magic" about it
    being a PDF file.
    R.K. McSwain
    http://cadpanacea.com
    *Dean Saadallah
    06-01-2010 12:57 PM in reply to: lydiageerlings
    Most common problem is you are not paying attention to two areas on the PDF
    READER print pop-up: see attached.
    Dean Saadallah
    http://LTisACAD.blogspot.com
