Solved by arshadmirza786. Go to Solution.
Brilliant, That worked on our HP Designjet 800 using the universal print driver win-x64-hpgl2-drv.exe file. (AutoCAD 2017 Windows 10).
Is there a special program I need to install these drivers? I click on the exe file and it unzips them to a temp folder however the extensions are not complete (ex_; dl_; da_)....that type of thing. these files are useless in this form.
Hi there,
For my HP Desingjet 500 on Windows 10 64bit & AutoCAD 2017 I'm using hpdj500wx64pclen.zip with success! driver is given with the link at the solution post #26
thank you guys.
WIN 7 PRO x64
I have successfully(though not consistently) plotted to the 800ps with the 800PS 42. I setup the plotter for HPGL2.
I have plotted several AUTOCAD 2015 drawings.
Additionally, I have also had moderate success using the 500 driver. Kinda squirly though.
I am also facing that type of plot error with HP plotter 500-800 in autocad 2018
Sorry to hear that, but which of the above suggestions have you tried and which results did you get?
- alfred -
facing same problem in window 10 , when I try to get print from autocad it is not allowing me select hp designjet 500 42 printer please help me to get proper driver.
