• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    *Greg Hubers
    dwg to pdf flattening process
    1178 Views, 33 Replies
    07-07-2009 11:04 AM
    When I create a pdf using the dwg to pdf driver native to acad2010 it
    creates a pdf but when I go to print that pdf the processing time that it
    takes to print is outrageously long since when adobe reader goes to process
    the pdf to print it it says it is "flattening" the pdf. Any idea how to
    remedy this problem? At this point the dwg to pdf driver in acad is
    unusable unless I can figure out how to create a pdf file that does not need
    to be "flattened" by adobe reader before finally sending off to the printer.
    Greg
    Please use plain text.
    *Dean Saadallah
    Re: dwg to pdf flattening process
    07-07-2009 01:07 PM in reply to: *Greg Hubers
    You need to use another PDF driver if you do not want layers and more type
    information in your PDF files. It's the way PDFs and DWFs are progressing in
    CAD, so don't go buying Adobe products either, grab a freebie pdf driver
    from vendors not spending any money developing their drivers.
    Dean Saadallah
    http://LTisACAD.blogspot.com
    *Terry Drewes
    07-07-2009 06:51 PM in reply to: *Greg Hubers
    Adobe Reader does that as a process to print the PDF. You might try
    using the latest reader version v9.1.2. Also, if you are printing large
    and/or high imaged PDFs (i.e. lots of hatch / tones), you might
    consider printing to file (i.e. myfile.prn) and spool it to the device /
    port direct. Then the print "processing" is complied at the PC, vs.
    across the LAN to the device.
    ~Terry
    > Thanks,
    > Greg
    *Greg Hubers
    07-08-2009 08:27 AM in reply to: *Greg Hubers
    Thanks for the responses Terry and Dean,
    I am using reader 9.1.2. I have been struggling with AutoCAD and pdf just
    like so many others for many years and have spent many hours/days trying to
    find a solution with very limited success. I was anticipating a usable
    product with dwg to pdf driver built into acad2010. I have tried many 3rd
    party pdf creators (My favorite being pdfCreator) but many of these rely on
    ghost and all have quirks of their own.
    I'm printing simple 2D model space stuff and was happy with the file sizes
    from acad - 100-200K average pdf size. I can direct print the pdf's as an
    image from adobe reader advanced print options and that is much faster but I
    do not have that option when printing sets of plans through reprodesk server
    to our Oce plotters. It can take literally hours for reprodesk to print 8
    pages from the pdf's I am getting from acad.
    I have tried turning off fonts, color, everything I can think of in the
    props of the dwg to pdf driver in acad with no success.
    The acad vs. pdf frustration continues...
    Greg
    "Terry Drewes" wrote in message
    news:6214653@discussion.autodesk.com...
    ~Terry
    > process
    > need
    > printer.
    > Thanks,
    > Greg
    *Terry Drewes
    07-08-2009 07:07 PM in reply to: *Greg Hubers
    If you plotting in-house, why not plot to Océ plot files? Re reprodesk,
    have you installed the ghost drivers to process pdfs natively?
    ~Terry
    > Greg
    > ~Terry
    >> process
    >> need
    >> printer.
    >> Thanks,
    >> Greg
    *Govert J. Knopper
    07-09-2009 04:07 AM in reply to: *Greg Hubers
    Is GhostScript used as the PDF converter in Reprodesk, or do you have Oce's
    own PostScript/PDF converter? (both are possible, but as the first is free,
    it's a "cheaper" option). I believe most owners opt for GhostScript.
    Behind the scenes of Reprodesk, GhostScript converts the PDF's to TIFF Group
    4. Processing of some PDF's with GhostScript can take much CPU resources and
    a long time, and Reprodesk is blocked during that processing. The file size
    is not so relevant, the complexity (hatches, layers, text) is more relevant.
    It may be more efficient to do the processing of PDF's "off-line": convert
    the PDF's to TIFF Group 4 on another machine or even the same machine with a
    separate program if the PC is powerfull enough. My GhostFriend frontend GUI
    for GhostScript (link to site below) helps to "batch" convert sets of PDF's
    to TIFF in a user friendly way. When that processing is done, just send the
    TIFF's to Reprodesk and they will plot almost immediately.
    If you happen to have the (optional, $$$) PS/PDF extension on the Oce
    plotter controller itself, you can also submit the PDF's straight to the
    machine. This is often much faster, but you can't use Reprodesk for this, so
    have to use other tools (Oce PrintExec, my GoPlot, ...) which offer limited
    layout (no preview) possibilities (which does not have to be a problem if
    the PDF's are properly made, btw).
    Govert
    http://www.noliturbare.com
    *Greg Hubers
    07-10-2009 09:30 AM in reply to: *Greg Hubers
    Well, it's a long story. But the short of it is, I used to have everyone
    scan to tiff, worked great, no problems, seldom had to mess with pdf
    problems. Then the bosses decided we need to scan to pdf without consulting
    me or asking my opinion. I would have tried to convince them to stay with
    tiff, or at least choose dwf or plt as the electronic format. But pdf was
    forced upon me and boy what a pain pdf's are in general. How much time I
    have wasted looking for solutions to pdf problems I can't even begin to
    guess.
    So I was hoping that pdf format would become more user friendly with
    acad2009 and now acad2010. We can still scan everything to pdf and they
    print ok, but scans tend to be muddy and shades of grey tend to get splotchy
    black/grey with the scans, plus if I don't clean the platen regularly the
    scans get streaks. So it would be nice to be able to plot directly from CAD
    to get a nice clean pdf . The pdf's are clean enough but it takes sometimes
    hours to flatten the pdf's that AutoCAD creates.
    I wish I could change the format but the bosses are convinced that we need
    to use pdf. They don't have to get them to work because "that's my job" :smileyhappy:
    They just don't realize how difficult pdf's are to deal with and frankly
    don't care.
    And yes, we use ghost on local pc's to process the pdf's in reprodesk.
    news:6215454@discussion.autodesk.com...
    ~Terry
    > to
    > on
    > I
    > server
    > Greg
    > ~Terry
    >> process
    >> need
    >> printer.
    >> Thanks,
    >> Greg
    *Greg Hubers
    07-10-2009 09:46 AM in reply to: *Greg Hubers
    Hi Govert,
    No money to buy Oce's postscript :smileysad: Budgets have basically slammed shut
    since last September. So we use gs to convert pdf to tiff in reprodesk.
    And I really don't want to switch away from reprodesk. I have PrintExec and
    client tools from Oce but we only use them as a backup when reprodesk is
    down. Reprodesk is very robust and has a nice accounting package which is
    critical here.
    As far as batch converting pdf to tiff I am trying to avoid more steps for
    the users and more data sitting on the server in the form of duplicate tiff
    files. It's truly amazing to me that wanting a clean and easy, user
    friendly pdf out of AutoCAD is so hard to come by. AutoCAD and Adobe are
    big and fat and enjoying all our $10,000's for licenses to their products
    and we don't even end up with the very basic tool to create a user friendly
    pdf. Talk about a conspiracy!!
    "Govert J. Knopper" wrote in message
    news:6215580@discussion.autodesk.com...
    Govert
    *Terry Drewes
    07-10-2009 06:53 PM in reply to: *Greg Hubers
    Maybe you need a faster conversion tool 3rd party software:
    http://www.adultpdf.com/products/pdftotiff/index.html
    http://www.pdf-convert.com/pdf2img/index.htm
    http://www.pdftoall.com/pdf-to-tiff.htm
    Put a share netfolder on the server, say plots... and have Users put the
    PDFs in that folder. Then run a O/S script / Task Scheduler to scan
    the folder, convert the PDFs to TIFF, and then move them to the
    Reprodesk folder for plotting. You could program the routine in a BAT,
    using the 3rd party tool and cmd commands to perform the move routines.
    http://www.iopus.com/guides/winscheduler.htm
    Then the processing of converting PDFs to TIFFs is taken out or
    Reprodesk, using GS, which just might be an issue with conversions, as
    you have experienced.
    ~Terry
    *Govert J. Knopper
    07-11-2009 02:21 AM in reply to: *Greg Hubers
    A couple of suggestions:
    1. Try an other PDF 'driver'; most - if not all - free ones use GhostScript
    to create PDF that is already very 'flat'. Autodesk has a strategic dilemma
    with PDF.
    2. Invest in a powerful PC for Reprodesk+GhostScript; GhostScript is *very*
    CPU-hungry when it processes PDF; if there is no budget, perhaps some PC's
    can be swapped, so that the fastest available PC is used for this job?
    3. See Terry's suggestion
    Govert
    critical here.
