• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    Valued Contributor
    Wipeouts not working in PDF in AC2013
    384 Views, 8 Replies
    01-11-2013 09:41 AM
    I thought we had this issue finally solved with AutoCAD 2012. When printing a PDF file wipeouts were working correctly. But then we replaced the machines with W7-64bit machines and started using AC2013. Now the wipeouts are not wiping out the background objects when you print using the "DWG to PDF.pc3" plotter.
    You can get around it by using the "Print As Image" check box in Adobe, but the end user of the file may not be aware of this fix and then his pdf prints do not read correctly.
    I've copied the DWG to PDF .pc3 and .pmp files from AC2012 to AC2013, but that didn't fix the issue.
    There are posts going back to 2001 regarding this issue and I'd really like to have it fixed.
    Please use plain text.
    pendean
    Re: Wipeouts not working in PDF in AC2013
    01-11-2013 09:52 AM in reply to: ajohnson
    LineMerge settings in the PDF pc3 file are the same in both versions?
    Or is your wipeout hovering below the content (or are you in paperspace)?
    Seems to be working just fine here so far.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Valued Contributor
    01-11-2013 11:46 AM in reply to: pendean
    Line Merge are both set to Overwrite.
    The lines to be masked are behind the wipeout. We are plotting from Paperspace.
    Good for you but not us.
    pendean
    01-11-2013 11:55 AM in reply to: ajohnson
    Can you post a sample DWG file where this fails for you? Have it ready to plot (save all your parameters in the layout that fails for you so we can use it as is). Delete any sensitive info and purge the file first of course.
    Valued Contributor
    01-11-2013 12:13 PM in reply to: pendean
    Now it appears that it is related to the Kip printer. Same pdf file printed to an HP 5200 is fine.
    But the problem is still with the end user. If they have a Kip printer, the results look bad.
    pendean
    01-11-2013 02:35 PM in reply to: ajohnson
    AutoCAD (the program) won't fix a limitation of 3rd party devices or their drivers: sorry. You'll find the same limitation on older HP printers/plotters/drivers too, the advice has always been to acquire newer devices or drivers if at all practical.
    Try a search in the older AutoCAD forums and the print-plot forum: they may list the actual KIP device you use and they may have a solution (you did not state which one, otherwise I would have attempted a search for you).
    Member
    alee
    01-29-2013 03:37 PM in reply to: ajohnson
    We have same issue at our office. we have same setting as 2012 version on 2013  and it only prints wrong on 2013 version. hard copies come out fine...it's just pdf files.. any idea how to fix this?
    Valued Contributor
    01-30-2013 05:32 AM in reply to: alee
    What printer are you printing the PDF files on?
    We use a KIP 3000 printer. Discovered if you change the printer properties from KIP GL to Kip Script the wipeouts started working fine again.
    Member
    alee
    01-30-2013 09:40 AM in reply to: ajohnson
    Thank you for your reply. I'm kinda new to the plot settings and all. we used to have a guy in our office who dealt with these sort of issues, but no longer, so i'm learning things as issues come up.
    Anyways, for PDF files, don't think we use are printer to make pdfs. We just use dwg to pdf.pc3 (pdf eplot - by autodesk)...wipeout comes out properly if we change the merge control to lines overwrite, but then we have to make sure all the layers we use are in proper order. reminds you we had same setting on 2012. wonder what changed between 2012 & 2013.
