• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    Active Member
    Publish option error
    158 Views, 6 Replies
    09-14-2012 03:44 PM
    It used to working until the last 2 weeks.
    When I want to print multiple pages, I go to file/publish/add sheet to the list/change page setup.  Then problem starts:
    1.  If it's plotting to paper, sometimes it only prints the sheets which are in the current opened file but not all the sheets on the list.
    2. If it's plotting PDF.  There's a publish options button.  I used to be able to use the publish option button and select the location of my PDF files and would it be dividable PDF files or just one PDF file with multiple pages.  PROBLEM NOW: If I click that, it'll just freeze the screen forever until I push "Esc" then it'll cancel the whole publishing function.
    does anyone have the same problem and how do you resolve this?  Thanks!
    Please use plain text.
    pendean
    Re: Publish option error
    09-17-2012 05:35 AM in reply to: Cad_enthusiast
    Sounds like you turned on Background Publishing: turn it off in OPTIONS' Plot tab.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Active Member
    10-16-2012 10:43 AM in reply to: pendean
    Hi thanks for your comment. however, I turned the publish background on and still not working....
    somehow the publish option button is not functioning suddenly. even i changed the publish details on options/plot and publish/automatic publish settings, it is not working....
    pendean
    10-16-2012 12:33 PM in reply to: Cad_enthusiast
    A system restore back to a month it all worked may be what you need to do.
    Active Member
    10-16-2012 12:57 PM in reply to: pendean
    Hi, you mean system restore AutoCAD 2013 or my window OS?
    pendean
    10-17-2012 06:03 AM in reply to: Cad_enthusiast
    Windows OS, unless you know something changes in AutoCAD.
    Active Member
    04-22-2013 03:52 PM in reply to: Cad_enthusiast
    Problem solved by repairing AutoDesk. =)
