Printing and Plotting
sagye
Message 1 of 13 (980 Views)
Problem With Wipeout Frames When Creating PDF Files
980 Views, 12 Replies
04-19-2005 10:23 PM
We are having a problem creating PDF files using Adobe Acrobat 6.0 from AutoCAD 2004 drawings that have wipeouts in them. The frame of the wipeout is either printing in solid black or as an outline.
I have created PDF files previously without any glitches. Any ideas?
Steve
*wfb
Message 2 of 13 (980 Views)
Re: Problem With Wipeout Frames When Creating PDF Files
04-20-2005 05:50 AM in reply to: sagye
I believe that the last time this came up there was no answer for Acrobat,
but other "pdf-ers" would work with wipeouts. I am not sure which ones.
Bill
wrote in message news:4819963@discussion.autodesk.com...
> Steve
*Dean Saadallah
Message 3 of 13 (980 Views)
04-20-2005 06:03 AM in reply to: sagye
PDF and Wipeouts don't go together. Topic discussed often, try a search
here.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
*Steve Adams
Message 4 of 13 (980 Views)
04-20-2005 09:32 AM in reply to: sagye
Steve,
My wipeouts behave like they are supposed to. I use AcroPlot.
http://www.cadzation.com/
> Steve
Distinguished Contributor
dloughnane
Message 5 of 13 (980 Views)
04-21-2005 07:31 PM in reply to: sagye
Where i just started working they were having the same problems. Our plotting to pdf process now consists of plotting to an eps file and then some how adobe recognises the file at it's location and converts it to a PDF and drops it into a different folder!!
Wipeouts work fine!!
*Frank Santelli
Message 6 of 13 (980 Views)
06-23-2005 06:22 AM in reply to: sagye
We use AcroPlot and do have the problem when the wipeouts are not square to
the sheet or with wipeouts that have mutiple vertices. Everything looks
fine when viewed on screen with Adobe 6.0, but when plotting (Xerox510) we
get solid patches where the wipeout is not square to the sheet if there are
any inside corners with multiple vertices. The same problem with xclips.
ANy help is appreciated
Frank Santelli
T.G. Miller, P.C.
"Steve Adams" wrote in message
news:4820573@discussion.autodesk.com...
Steve,
> Steve
ryansteele
Message 7 of 13 (980 Views)
07-12-2005 03:24 PM in reply to: sagye
One workaround is the obvious one, create a layer, set it to white (actual white, 255,255,255) and move all wipeouts to that layer. Or use acrobat 5.0, it still works with wipeouts, 6.0 and 7.0 don't, well done adobe, manage to go backwards.
Member
sdiercks
Message 8 of 13 (980 Views)
08-11-2005 08:33 AM in reply to: sagye
Under the Advanced button on the Acrobat Print dialog, check print as image and see if that helps. I am using Version 7 of Acrobat reader. Creating the PDF direct from AutoCAD with a variety of PDF creators did not fix the problem. Using the Print as Image option appears to have solved the problem.
Active Contributor
goodjuju
Message 9 of 13 (980 Views)
11-23-2005 01:23 AM in reply to: sagye
A lot of the time it is actually to do with the print driver you are using.
If we plot the PDF to our Xerox printers using a Postscript driver we get the solid black areas where the Wipeout should be.
If we plot exactly the same file to an HP Printer using a PCL driver, the wipeouts behave correctly.
Active Contributor
goodjuju
Message 10 of 13 (980 Views)
11-29-2005 04:51 AM in reply to: sagye
Try going to your 'Distiller Printer' and looking at the printer properties.
Under the 'Advanced' tab 'Print Processor', try changing from 'WinPrint' 'RAW' to 'WinPrint' 'INGR'.
This worked for me.
You are not logged in.
Ask the Community
