Show only
Search instead for
Looks like the format is not forwarded correctly to the printer when printing A3, it comes out as A4. If we change paper format in printer properties to A3 it works fine.
1. What are you plotting to? 2. using what driver? Driver version? 3. AutoCAD version? 4. Do you use a PC3 file or plot directly to the WIndows system driver? 5. If you have AutoCAD installed and are using it on Win Server 2012 then that is an unsupported OS and there is no official fix.
