Printing and Plotting
bassnbuddy
Message 1 of 9 (164 Views)
Plotting too light
164 Views, 8 Replies
06-25-2012 02:58 PM
Can someone please explain why files received from different architects affect how my plot style prints?  I'm using my set plotstyle but plots are almost too light to read.  Layers are set to default line weights in both files.  This printing problem happens in both model and paper space.  Using AutoCAD 2012 standard.  Would like to know if anyone else has this problem.
pendean
Message 2 of 9 (163 Views)
Re: Plotting too light
06-25-2012 03:02 PM in reply to: bassnbuddy
CTB or STB?
or LWEIGHT settings?
What is the Visual Style settings in each file?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
bassnbuddy
Message 3 of 9 (158 Views)
06-26-2012 07:36 AM in reply to: pendean
Not sure how to answer your question, not sure what CTB or STB is. Don't feel it is the line weight steetings, have double checked against another dwg file that prints as intended. Let me know if I need to send dwg files. Louise Howard ><(((((º>`·.¸¸.·´¯`·.¸.·´·...¸><(((º>¸. ·´¯`·.¸. , . .·`·.. ><(((º>`·.¸¸.·´`·.¸.·´¯`·...¸><((((º> 334.355.0326 cell Louise Howard ><(((((º>`·.¸¸.·´¯`·.¸.·´·...¸><(((º>¸. ·´¯`·.¸. , . .·`·.. ><(((º>`·.¸¸.·´`·.¸.·´¯`·...¸><((((º> 334.355.0326 cell
pendean
Message 4 of 9 (157 Views)
06-26-2012 07:48 AM in reply to: bassnbuddy
You don't know what type of plot style table you are using? Or if you use one?
SAo what does "too light" mean then?
bassnbuddy
Message 5 of 9 (156 Views)
06-26-2012 09:49 AM in reply to: pendean
I have a set plot style that I use for all my dwg files, but this particular file doesn't appear to follow it. I didn't understand what CTB or STB stood for. Use a ctb plot style. After rethinking, this happend once before when that architect was using Rivit. Is it possible there is a communication problem between the 2 programs? Using AutoCAD 2012. Louise Howard ><(((((º>`·.¸¸.·´¯`·.¸.·´·...¸><(((º>¸. ·´¯`·.¸. , . .·`·.. ><(((º>`·.¸¸.·´`·.¸.·´¯`·...¸><((((º> 334.355.0326 cell
pendean
Message 6 of 9 (154 Views)
06-26-2012 10:03 AM in reply to: bassnbuddy
There are two types of plot style tables: STB (relies on your actively setting objects and layers) and CTB (uses screen color). When posting for remote assistance, it helps if detailed information is shared: thank you for doing so in this last reply (CTB).
Can you better define "too light"?
bassnbuddy
Message 7 of 9 (151 Views)
06-26-2012 03:06 PM in reply to: pendean
Will have to get back to you on Friday. Louise Howard ><(((((º>`·.¸¸.·´¯`·.¸.·´·...¸><(((º>¸. ·´¯`·.¸. , . .·`·.. ><(((º>`·.¸¸.·´`·.¸.·´¯`·...¸><((((º> 334.355.0326 cell
pendean
Message 8 of 9 (143 Views)
06-28-2012 06:09 AM in reply to: bassnbuddy
Hope it's something fun :smileyhappy:
bassnbuddy
Message 9 of 9 (142 Views)
06-28-2012 08:36 AM in reply to: pendean
No, just an food service equipment training session. OK, the print appears to be in draft mode, all lines are the same weight. Thought it might be related to the rivit created xref so I drew my own base plan, inserted and ran another plot, no change. Its not the title block because the second sheet in the set does not include the xref and plots correctly. If you have access to dropbox can upload some files so you can see my problem. Louise Howard ><(((((º>`·.¸¸.·´¯`·.¸.·´·...¸><(((º>¸. ·´¯`·.¸. , . .·`·.. ><(((º>`·.¸¸.·´`·.¸.·´¯`·...¸><((((º> 334.355.0326 cell
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
