Printing and Plotting
joecycler77
Message 1 of 3 (1,208 Views)
Plotting to PDF, lineweight too thick?
1208 Views, 2 Replies
11-30-2010 09:40 AM
I have already checked LWT and it's set to default, aclt.ctb is selected, and my drawings are plotting to PDF with line thickness much heavier than what is represented on the CAD viewport?  I am using the full version of Adobe Acrobat 7.0 as well.  I have read through and tried all of the suggestions on this board and nothing seems to work?
Any help would be appreciated.
*Expert Elite*
pendean
Message 2 of 3 (1,202 Views)
Re: Plotting to PDF, lineweight too thick?
11-30-2010 10:39 AM in reply to: joecycler77
Are you plotting with the dwg to pdf.pc3 file? or something else?
AutoCAD version?
Did you try any settings changes to PDF driver output?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
joecycler77
Message 3 of 3 (1,197 Views)
11-30-2010 11:30 AM in reply to: pendean
I figured out that my default line weight setting was set to 0.25mm, which was causing the problem.
Thanks for the reply.
You are not logged in.
Announcements
Need installation help?
Ask the Community
