why the drawing plots results using the viewport scale in the layout is not accurate?
guys, please help me solve this problem.
Hi there welcome to the forums
There are wiser folk here than me that will have better answers I'm sure but some things to check.
One question that will probably be asked is what version of Autocad are you using?
I don't know the depth of your use so forgive me if I suggest simple things you have already tried.
Is the scale in your vport actually set & to a recognized scale i.e.. 1:100
Have you set your paperspace to suit your plotter.
In the plot set up is the correct size of paper showing?
Is your plot set at 1:1 rather than fit to paper
Is the plot set to the same units as your drawing i.e.. Centimeters?
Have a look at those things & see they are correct then if not let us know & I feel sure someone will have more ideas for you.
Should this solve your problem please mark as resolved to help others looking for answers
