• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    Distinguished Contributor
    Large Format PostScript Origin/Rotation Problems
    148 Views, 3 Replies
    09-13-2012 08:09 AM
    I have had problems printing large format drawings to a KIP 3000 and an Oce 860 using PostScript drivers .  Occasionally, a drawing will seem to lose its mind and experience an origin shift and/or rotation problem.  The net result is a drawing that is shifted on the page - even a blank page - to the point where it is unusable.  In EVERY case, the plot preview shows an absolutely normal and expected result.  This doesn't happen with PostScript drivers for smaller printers AND it doesn't happen with ANY OTHER application than AutoCAD trying to print to those devices.  This includes other Autodesk products like Inventor.  Sometimes, the problem can be fixed by a copy/paste of everything from the problem drawing into a new drawing started without a template.  The two printers are at different companies with no shared drawings, different versions of AutoCAD (2009/2011), different computers, different operating systems (XP Media Center 32-bit/ Win7 64-bit).  I have plotted to a file and used GSView to look at the PostScript in the files and the results on the screen are the same as the results on paper (not good).  I'm looking less for an answer than just learning if anybody else has seen this.  If you have either of these plotters, can I post a drawing to see if you experience the same thing?
    Please use plain text.
    Valued Contributor
    Re: Large Format PostScript Origin/Rotation Problems
    09-27-2012 11:05 AM in reply to: cascadtx
    I would suggest trying a plot file.... or converting your pdf to a jpeg or tiff file and send it not scaled.  Unless you have some oce prioprietary software they are a pain in the woohooo to deal with post script.  We use print exec lt but it's super limited and the controller HATES pdf files even with the post script enabled.
    If you make a plot file or convert to a tiff file you can send to the printer using goverts goplot and a simple printer thats shared on the server :smileyhappy:
    *Expert Elite*
    pendean
    09-27-2012 12:57 PM in reply to: cascadtx
    Since pasting into another presumably empty or clean template file fixes the problem, I would say the issue is a setting in the problem file and not much else.
    Could be a simple thing like an incorrectly selected pagesetup, or referenced pmp or pc3 file, or more dramatic like the wrong layout settings. hard to tell without a DWG file.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    09-27-2012 05:10 PM in reply to: cascadtx
    Again, I'm primarily looking for others who have experienced this problem or who have one of these plotters and would be willing to get a drawing from me to try.
