• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    Member
    Generic Print Areas
    113 Views, 2 Replies
    04-25-2012 05:27 AM
    We have 15 offices worldwide using AutoCAD with a Standard Template for ISO papersizes (A0, A1, A2, A3 & A4) however we have different printers/plotters in different offices.
    Does anybody know of a generic print area that i can set the blocks too? if i set the print area for the OCE plotters they do not suit the HP Designjets etc.
    Same issue when printing to pdf.
    I need a suitable print area for All ISO sheet sizes that will work with any plotter/printer & pdf driver.
    Any suggestions?
    Gary Cleary TIFireE
    CAD Manager
    EC Harris LLP
    Please use plain text.
    pendean
    Re: Generic Print Areas
    04-26-2012 05:52 AM in reply to: gary.cleary
    Find the one device you use most with the largest margins, and set up your sheets for that device (DWG to PDF.PC3 file seems to fit that bill for us). Otherwise, there is no magic bullet, you pretty much have to develop this one in-house with your choices for output.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    04-26-2012 06:29 AM in reply to: pendean
    Thanks for the update.
    i took a sample of 4 printers/plotter/pc3 files this morning & came up the with the meanest drawing area being that of the DWG to PDF.pc3 file
    this has now been used.
    Gary Cleary TIFireE
    CAD Manager
    EC Harris LLP
