AutoCAD Forum
GAS drawing takes approx. 1 hour for just ploting preview & creating pdf file.
5 REPLIES 5
455 Views, 5 Replies
Dear Autodesk Family,
For our any General Arrangement Skid(GAS) drawing, the drawing file takes approx. 30min to 1 hour for just plot preview and creating the pdf file.
Also after the creation of pdf,sometimes few parts are missing in the pdf.
The sample pdf is attached here.
Note 1:
Its a AutoPlant ISOMETRIC model. Its having xref many files attached.
Currently the drawing pdf I shared is having drawing .dwg file size of 1.01 MB .
Also the plot preview setting is given second attachment.
Please let me know any solution/setting for fast ploting and fast pdf creartion
Waiting for your earliest reply.
Note 2: We are using:
Software :   Autocad 2012-64Bit , Bentley Autoplant V8i - SS4 version : 8.11.9.140 , Naviswork 2013 , Inventor Ultimate 2014-64 Bit , MS-Office 2010 - 64 Bit.
Hardware : Workstation Dell Precision T3600
5 REPLIES 5
pendean
What's the FINPRT13 driver that you are using there?
in reply to: pendean
Dear,
Its our pdf driver printer.
We also tried by local DWG to PDF.pc3,then also it takes same time.
Waiting for any solution.
pendean
Slow plotting is either content or driver setting related: if you want to share the actual DWG file someone here may observe a solution.
Dear,
Please have a look on the sample etransmit file uploaded at following link.
http://www.fileconvoy.com/dfl.php?id=ge516da2776fb5651999445660e0707698d77563da
Waiting for solution of fast ploting and creating pdf..
pendean
Since the majority of your 16 XREFs are 3D detailed plant or plant-components drawings, plotting is going to be slow: goes back to what was noted earlier, content in your files is the reason for slowness. There is no 'fix', it's a lot of 3D info to squeeze into a 2D flat paper/PDF plot.
RECOVERALL command did find some minor errors in your Xrefs but not enough to make a difference.
”Boost
