AutoCAD Forum
Fill hatch won't print as a solid.
1 REPLY 1
1450 Views, 1 Reply
I am trying to create logo's as blocks to insert into title blocks efficiently. I made the outline of the first logo and hatched it as a solid hoping it would print as a flat black but it is showing up as streaky, almost as if I used a different hatch at an extremely small scale. I don't think it is a printer issue because even when printed to .pdf format it still shows up as streaky.
Any suggestions on how to fix this are greatly appreciated.
Tags (3)
1 REPLY 1
pendean
in reply to: 480603
Increase your pen weight or make then color 7: solids are triangulated shapes in AutoCAD as you can see in the PDF.
Or explode using SOLID command to draw true solid fills.
”Boost
