AutoCAD Forum
EXPORTPDF Command
3 REPLIES 3
1541 Views, 3 Replies
EXPORTPDF Command
On DWG Trueview, I want to export a PDF from a DWG Drawings, I make the following script (.scr) :
Spoiler
;BEGIN SCRIPT
ExportPDF
;END SCRIPT
DWG TrueView opens and displays the PDF registration popup.
it is possible to save the exported PDF Automatically to a folder without user interaction ? what i have to add to the script or configuration for that ?
Thank you in advance.
3 REPLIES 3
Slawomir_
Hi soubari,
I've wrote short script in AutoCAD but I hope that it should run also on DWG Trueview. I'm not using EXPORTPDF command because it does not have command line. EXPORT command will let You save pdf but You need to first manually specify path and name of Your pdf file. You can also try to write AutoLISP routine to read and write dwg name automatically.
TILEMODE
0
(command "_-EXPORT" "_PDF" "_C" "_NO" "C:\\Users\\Sample_folder\\file_name.pdf")
Remember to write Your path and filename.
Tags (3)
pendean
in reply to: Slawomir_
There is no SCRIPT command in DTV: but is has a PUBLISH command that will "export" to PDFs all day long from one or hundreds of files.
Slawomir_
in reply to: pendean
Thanks for correcting me 😃
”Boost
