In AutoCAD 2014 and ASD2013 I cannot choose one of the printer, which is installed on Windows (OCE TDS600). It is strange, because Autocad sees it on the list of available plotters, but when I try to select it - it automaticly changes to "None".
The plotter is properly configured - I can print with it from Revit 2013 without any problems. Also when I switch account to any other (on that same computer) everything works fine.
I tried to add this plotter through "Add-A-Plotter Wizard", but each time I obtain an error massage "Autodesk Hardcopy component failed..."
Do you have any ideas have to solve this problem?
PS. A short movie with this problem: https://www.dropbox.com/s/3jtaxggtzl0wwj7/print_error.avi
