Printing and Plotting
Dasharnb777
Message 1 of 3 (339 Views)
Automatic plotter changing/replacing (maybe AutoLISP).
339 Views, 2 Replies
03-21-2012 03:26 PM
I need to change printer/plotter (maybe PC3 file) on my drawings. For example I have 'printerN.pc3' setted and I need to set 'PrinterM.pc3'. Also need to change print scale. But since I have many drawing I need somithing thatcan do iy automatically. So what I need:
I need to replace specific plotter to anither plotter:
1. For example if plotter setted to "HP" -> change to "Canon"
2. If paper size (2) is A3, set Plot scale (3) to 1:1.015, if Paper size (2) - A4, set Plot scale (3) to 1:1.02
Seems like I can do it with AutoLISP.
So I need your suggestions, where to look. Thanx a lot.
*** Using AutoCAD 2009 and 2011***
pendean
Message 2 of 3 (322 Views)
Re: Automatic plotter changing/replacing (maybe AutoLISP).
03-22-2012 06:08 AM in reply to: Dasharnb777
-PLOT command, write a simple script then use SCRIPTPRO tool free from Autodesk to run it in all your files.
Explore this as a tool, modify to meet your needs:
http://cad-notes.com/2012/03/learn-how-to-write-command-scripts-for-autocad-and-automate-your-plotti...
Explore and get into PUBLISH command and skip this per-file plotting method.
Get into SSM and manager projects even better (not an option in R2004) if these are all single project related needs.
Lisp Customization Discussion area:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Dasharnb777
Message 3 of 3 (318 Views)
03-22-2012 11:13 AM in reply to: pendean
Thanx a lot for the reply, I will check it out. Anyway thanx!
You are not logged in.
Ask the Community
