• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    New Member
    rassar83
    Accepted Solution
    Arabic Fonts Jumbled after plot in Autocad
    3941 Views, 5 Replies
    02-21-2011 04:21 AM
    Arabic Fonts Jumbled in Autocad. . .
    When i see in autocad it look very clear, when i see preview also, it is very clear. . .
    When i plot drawing, it is coming Fonts Jumbled. . .
    Can any one help me to reslove this iusse . . . .
    see the drawing. . . . .
    Please use plain text.
    *Expert Elite*
    pendean
    Re: Arabic Fonts Jumbled after plot in Autocad
    02-21-2011 07:22 AM in reply to: rassar83
    Plotting to what?
    Using what driver?
    How is that driver handling font capture (appears to be the issue)?
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    New Member
    rassar83
    02-21-2011 09:30 PM in reply to: pendean
    With reference to your reply. . . . .
    I would like to update my complete information to you. . . .
    I am using Winxp SP2 Operating System. . . .
    My Plotter Information - HP 800PS. . . . .
    My autocad version - 2007 & 2008. . . . .
    My Fonts are loaded in autocad is more than 3510 . . . . Including Arabic Fonts . . . .
    When i see the preview it looks correctly, but after plotting it comes to different look. . . . . .
    Still My autocad plot arabic text like individual alphabets. . . . . in A0 Drawings + A4 Sketch . . . .
    Already u have gone to my attached pdf file . . . . the same thing i get in all drawings. . .  .
    Even i change autocad version also, again the problem occurs to be same. . . . .
    Can you guide me to the appropriate solution . . . .
    I would be much thankful to you in advance. . . . . . .
    Regards
    RASSAR
    *Expert Elite*
    pendean
    02-22-2011 04:54 AM in reply to: rassar83
    See the following link to similar issues, hope these help:
    http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=location&location=Node%3A30&q=ara...
    Active Member
    06-19-2011 12:39 AM in reply to: rassar83
    I once had a need to plot such drawing.  We found that only HP LaserJet 5550 prints it fine.  Since 5550 is an A3 printer, we have to tile and stitch to come up with an A0 plot.  Later on we discovered that Dassault Systemes Draftsight works well with Arabic fonts but you must do the Arabic typing from Draftsight.  Unfortunately, Draftsight is 2D so you're out of luck when you have to deal with 3D dwgs.
    Autodesk, please solve this problem.
    New Member
    navask028
    02-08-2012 01:45 AM in reply to: rassar83
    HELLO  ...SIR  WHEN I TAKE PRINT  D.W.G  DRAWING  THE ARABIC LETTER IS COMMING INCORRECTLY...   HOW TO  SOLVE THIS PROBLEM ,,,, PLEASE TELL ME VERY QUICKLY
