Printing and Plotting
Active Member
ets-tech1
Message 1 of 5 (3,132 Views)
AUTOCAD 2012 crashes when printing to the plotter
3132 Views, 4 Replies
09-28-2011 09:21 AM
Hello Forum,
Autocad freezes when selecting a plotter. The Plotter is an HP designjet 500(http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18...).  The drivers are upto date. We have three other plotter, same result. No issues in printing on a laser/color printer which are on a network.
Plotter are on a network,managed by a print server.I  have used a HP universal driver, which stopped the freezing but nothing would print.
System Configuration:
Dell Optiplex 990, I5 processor
10GB Ram
500 GB HD
Windows 7 Enterprise 64 bit.
Need to fix this ASAP.
I
Distinguished Contributor
Message 2 of 5 (3,059 Views)
Re: AUTOCAD 2012 crashes when printing to the plotter
10-12-2011 11:50 AM in reply to: ets-tech1
We had a similar issue when we moved to Windows 7 / AutoCAD 2011.. going to an HP 5550. The solution was to add a custom sheet size for our 11x17 prints. and it's been working since.
See this:
http://forums.autodesk.com/t5/AutoCAD-2011/Can-t-Print-11x17-to-HP-Printers-with-Autocad-2011-and-Wi...
*Expert Elite*
pendean
Message 3 of 5 (3,039 Views)
10-13-2011 06:08 AM in reply to: TherealJD
Message 4 of 5 (2,702 Views)
01-31-2012 02:34 PM in reply to: ets-tech1
Can you print 8.5x11 and not 11x17?
Are you running a post script print driver?
If you are running Windows 7 64 bit  AutoCAD 2010 or higher and you a using an HP post script driver select 11x17 and it will most likely crash.
Try a HP PLC driver the qaulity may be lower but it beats crashing with no print.
Product Support
Message 5 of 5 (2,659 Views)
02-08-2012 04:04 PM in reply to: ets-tech1
I would definitely make sure you have the latest Universal Driver from HP, and there are three choices:
PCL5
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=ds-99378-2
PCL6
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=ds-99374-2
PostScript
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=ds-99376-2
One of these may work better than the other. AutoCAD tends to do better with non-PostScript too. I'd try the PCL5 one first.
If these don't help, then it must bee something with the print server and how it's handling the driver. I've seen a couple cases on this where the driver was thought to be updated but the server was still using the old one.
Bryce Thelin
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
