Hi all,
I'm making my first part with CAM360 on my Sherline mill. I'm using the EMC post. I did a few 2D profiles and pockets with no problems whatsoever. However with my first 3D adaptive toolpath, the tool plunged into the material a few times during a rapid move just before engaging into a feed cut again. I'm attaching a picture, hope you can make out the details. I'm hoping somebody can take a look at my file and see what I'm doing wrong.
Lorne
Hi Lorne,
Can you see the issue in the Simulation? If not, it might be related to post customization (e.g. if your CNC is set up to do dog-leg motion for G0s) in which case you can send a mail to the post team at cam.posts@autodesk.com. They should be able to help you out.
If the issue is visible during simulation we can have a look at your toolpath.
René
The simulator definitely does not show the issues I'm referring to, so it could very well be a post processor issue. I will contact the post team, thanks.
Ok. I have let the post team know to expect your mail 🙂
lorne,
Did you get this resolved? I spoke with our Post Team and they hadn't heard back.
If you can send an invite to Andrew in the Post Team he can take a look at your file, and your post, to determine what might be the cause.
Anthony Graves
Product Manager, CAM
I am having a similar problem. It doesn't happen every time... but I am creating multiple 2d profiles, then post processing them to generic Mach 3. I am milling parts from plywood.
They hit the stock during preparatory moves (before the actual cut begins). I cant see any option to control, or even properly display preparatory moves in your CAM... that would be nice.
I noticed that I can eliminate this behavior by setting all the clearance, feed, etc heights to be relative to the stock, not eachother.
Abel Zyl
Abel,
This should not be the case, but I suspect that it may be the way the part is being programmed (note on the heights for example). However, to be sure it would be best if you could share your project with someone on our support team. Please share your project with jeff.walters@autodesk.com and shoot him a quick email so you can set up a time to review it with each other.
If this is a post issue Jeff will be able to communicate what is needed to our post development team.
Anthony Graves
I haven’t received the invite yet so I hope you have solved the issue. If not id me more than happy to take a look at it with you.
