• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Pointing-Devices and Displays
    Active Member
    wesleylau
    Moving 3D mouse cancels command
    356 Views, 6 Replies
    06-14-2011 03:52 PM
    I have AutoCAD LT 2011 and a 3D Connexion space navigator. My problem is that whenever I move the mouse, the command that I'm currently on gets canceled. For example, if I am moving something and it's asking me for the target location and I move the 3d mouse to navigate there, I get canceled out of the move command. This essentially means I can't use my 3d mouse for commands (a big problem!).
    Anybody else have this issue and how did they resolve it?
    Also, I used to use AutoCAD 2008 and didn't have any problems. I emailed Logitech, but they said that AutoCAD now handles the 3d connexion drivers (version 2011 and up), so they can't help me...
    Please use plain text.
    Valued Contributor
    Re: Moving 3D mouse cancels command
    07-15-2011 06:56 AM in reply to: wesleylau
    We are experiencing the exact same problem, with ACAD 2012 and 3Dconnexion Space Navigator USB, latest drivers.
    -Geo.
    Valued Contributor
    12-07-2011 06:19 PM in reply to: wesleylau
    Has a solution to this been found by anyone? Thanks.
    Valued Contributor
    12-08-2011 04:57 AM in reply to: DianneS
    Nope. Not using AutoCAD has been working the best. Otherwise, I am not touching the puck at all if using AutoCAD (rare use).
    Geo.
    Active Member
    wesleylau
    12-08-2011 06:47 AM in reply to: wesleylau
    No working solutions so far. You can see what some people have said on the other thread I started, but none of the solutions there worked for me. http://forums.autodesk.com/t5/AutoCAD-LT/Moving-3D-mouse-cancels-command/td-p/3057416
    Valued Contributor
    12-09-2011 06:29 AM in reply to: wesleylau
    I found that post as well but ideas did not work for me either.
    Valued Contributor
    01-04-2012 11:36 AM in reply to: DianneS
    This solution from 3Dconnxion through their facebook page: Set the visual style to anything other than 2dwireframe.  So now I'm using plain wireframe when working in top view and no cancelled commands when panning or zooming. Awesome!!! Just make sure nav cube and nav bar are on.
