• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Pointing-Devices and Displays
    Member
    rickrob
    Logitech M305 mouse & middle wheel. AutoCAD2011 LT. Mouse wheel PAN function.
    636 Views, 4 Replies
    03-19-2012 11:04 AM
    Been using Logitech M305 for over a year.  With AutoCAD 2011, middle wheel... when pressed does not PAN. Checked with Logitech.  Ran tests & middle wheel works fine on web page, scrolling up and down.  When in AutoCAD, I've entered the mbuttonpan and set to "1".  When wheel is pressed straight down, crosshairs stay with no change.   I don't know what else to do.  Been using this mouse for over an year with no problems.  Have fast track project and need help please!
    Please use plain text.
    New Member
    Re: Logitech M305 mouse & middle wheel. AutoCAD2011 LT. Mouse wheel PAN fu
    03-19-2012 08:36 PM in reply to: rickrob
    I have the same problem with the M305 and Maya 2011.  Middle mouse click does not pan.  I'm just going to get another mouse.
    New Member
    03-19-2012 08:48 PM in reply to: rickrob
    Solved:
    1. Download the SetPoint app from Logitech's site.
    2. In the SetPoint utility, under Button Settings -> Select Button, Make sure item 3 is set to "Generic Button"
    That did it for me!  Didn't even have to relaunch Autodesk Maya.
    Charles_Shade
    03-20-2012 04:44 AM in reply to: bagg68
    OP - If this works for you please mark as Solved.
    Please mark any response as "Accept as Solution" if it answers your question.
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Member
    rickrob
    03-21-2012 03:45 PM in reply to: rickrob
    Seems as though Logitech has changed their options as well as selections on what you can do with the wheel.  I tried somehting that I thought would not work... I selected for button 3 "Middle Button", clicked apply and OK, it worked.  It is only in the new revision.  I hate changes...
    Rickrob
