How can i get a link to view my project (PROXY MESH AND LOW RES TEXTURE) which anyone i give it to, can use to see my photogrammetized model.
You can get a link for the model by going to autodesk360.com
- Use the same credentials you use for the ReCap 360 service;
- Access your documents and the file you wish to share;
- Right click on the RCP and select Public sharing;
- When you'll turn-on this option you'll get a link that you can copy and share;
- Anyone with the link would be able to access and view the model;
- They’ll have access only to the files for which you have provided a link;
Note, in order the other User to view the model he’ll first need to sign-in to Autodesk.
Mitko
I haven't been able to find a non clunky way to share a model yet. I don't want to force people to register with Autodesk to view a sample. The advertised method that was just listed also doesn't seem to reliably work. Sometimes I get a 'you are unauthorized' or another 'can't find blabla' error.
I have been exporting to OBJ and placing them up on sketchfab.com. Which sort of stinks because you need to take an extra step but Autodesk needs to have a way to show people content without forcing them to register.
Matt
I just to do the same, download and post on sketchfab, but recently I have started using the 360 sharing feature. I do also dislike the mandatory login for people to view, but the advantage is that when people are using a mobile/ipad there is a native app that really displays the model super great, compared to the basic rotation with sketchfab.
