ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Mesh view makes parts dissapear
9 REPLIES 9
Message 1 of 10
JamesMaeding
536 Views, 9 Replies
If I am zommed in close, I see the model.
As I zoom back a bit and orbit, portions go away as if the lighting is making triangles dissapear, see images.
Also, once the bounding box is displayed, it won't go away.
I am in chrome on a win 7 64 machine, lots of ram and high end vid card - nvidea k4100m
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
9 REPLIES 9
Message 2 of 10
JamesMaeding
in reply to: JamesMaeding
I see whats causing this now.
If you pick one of the photos, it shows the photo and model lined up for a second or two.
Then things go haywire and the triangles act odd. Its very confusing as the image is gone, yet the model is there.
How can I get rid of that "photo overlay" mode, as selecting another just switches to it. You cannot get out of that mode.
You have to close chrome and re-open to get the model back to regular currently.
Also, can I make the preview longer, before the image goes away?
Message 3 of 10
ideerge
Hello, can you share the project with us recap360@autodesk.com, so we can explore this problem further? this is new.
Message 4 of 10
JamesMaeding
in reply to: ideerge
sure, it is shared now. Modify as you please, its just a test.
Message 5 of 10
ideerge
I dont see anything wrong with it, i can go from one camera position to another for all your photos and your model stays the same
would you mind going to Menu - Tools - Clear Browsing Data - Clear Caches from beginning of time to see if it is going to be better?
Message 6 of 10
JamesMaeding
I did the clear cache step a couple times, it has no effect.
I must close chrome and reopen to get back to normal.
chrome version is Version 35.0.1916.153 m
I can consistently reproduce the error so we can try whatever makes sense to narrow down.
Message 7 of 10
JamesMaeding
hold everything.
I did an update on chrome to Version 36.0.1985.125 m, and it all works now.
Seems that is critical. Issues solved.
Message 8 of 10
JamesMaeding
while on this, didn't you think the model results were average?
The corners of the bldg were not great, and lots of things came out wierd compared to what I expected.
I was basically getting what I considered a minimum number of pics for a model, but things like the blue awning came out horrible, and I had at least three angles on it.
Any idea why it did so bad on that?
Message 9 of 10
ideerge
I dont think you have enough pictures, the thing is you need to take the pictures continuously from one to another with a lot of angles, and survey points are good to make sure your edge stays sharp.
we had constomers taking 200 images to just capture a small object.
Message 10 of 10
JamesMaeding
hmm, even after trying with many more pictures, some projects fail and some come out rather "melted".
I have yet to see decent results on things I thought would be easy.
200 pics is a lot too. Just keeping track of that many is tricky "did I already take from this angle?...."
Rail Community
