Hi Dev team. I was thinking how much nicer my scan came out after I assigned some manual points this past weekend. It probably would be kind of neat to be able to manually assign points during that first review. Just to give recap a hand initially. Some of the trickier stuff.
Anyway, that's my big idea this week. Stay tuned for more 😉
Matt
Solved by vidanom. Go to Solution.
Hi Matt,
Thank you again for this.
However, I know we have this option available before submit.
Please check the attached image, and let me know if you don’t have the “Advanced” button.
That should open the registration tab.
Mitko
Thanks, But there is no such button on my screen. See attached.
Does this feature require a subscription? If so I'll probably get one today because I was impressed with the results I got after assigning some points.
Matt
Yes, registration tab before submitting projects is only available with subscription.
But be careful, if some photos were not stitched, the outcome is more likely because of the photos that were used than the placed targets.
Best,
Mitko
