I am working on a project that requires me to have particles that increase and decrease their speed over time. I am fairly new to using the particle system in max, and I haven't been able to find any tutorials that have been able to help me with this. The particles need to gain speed over a period of time, and then slow back down. Does anyone have any ideas for how I could go about doing something like this? I am using pf source, I don't wish to download any external plugins(unless they are free for commercial use)
Solved by BenBisares. Go to Solution.
It depends on what you are using to make the particles move. Off the top of my head:
-If you are using the "Speed" operator you can animate the speed value
-Use forces like drag or wind to change their speed
-Use the "Speed Test" operator to take particles over/under a certain speed and then output them to another event where there's another operator that will change the speed
Can you show me an example or give more detail as to what you would like to achieve? I could then try to give you something more specific.
I tried some of your suggestions, and worked something out that is to my liking...Thanks a bunch!
Glad to hear that they helped. If you have any follow-up questions don't hestiate to ask.
I actually just turned on 'autokey' and changed my speed operator value. For some reason, the first time I tried it, it didnt work, and I was like 'oh well,must not be right'. But upon trying it again, it worked..I started by turning on autokeying, adding a key manually at the beginning, and then moving to the frame I wanted the particle's speed to be at the maximum, went and changed the value in the particle system's speed operator. This makes a key for you, and from there you can just go on changing the speed operator at the frame you want it to slow down or speed up at.
