I have two enhancements that would greatly improve our workflow communications using the email scripting object
Currently the Email scripting object has only three properties (To, Subject & Body)
It would be great to add an Attachment property most likely an array that could be populated via the script from workspace references to attachements in the system. - Great use would be to allow transmittal of pdf files to a supplier in an RFQ workflow.
Second (and not sure if this is possible) - allow for a default return email address (such as a company generic email address) to be the From address rather than the NoReplyAutodesk address. This would only be used by Script generated emails - the standard workflow email should remain as is. You could define this address in one of two ways.
1. Setup in Admin a company default address that can be read via scripting
2. Get the user email address from the user information at the time the script is executed
BD
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
