I realize this is a big request, but here goes anyway.
I would like to have a Item Details layout that can change with workflow stage.
Often I only want to see a few fields in a given workflow stage.
I woud like if I could create different versions of the "Item Details Fields" view and specify which views to use in a given workflow stage.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
