Ability for a Tenant Administrator to lock all User accounts from access to a tenant.
Allows Tenant Administrators create a Maintenance window to run imports/updates/reports etc with the knowledge that no tenant users are connected to the Tenant.
Also support presenting a Message similar to the Autodesk Maintenance window
Ability to select all Active Accounts and set to Locked Out status
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
