Tenant Administration
Ability for a Tenant Administrator to lock all User accounts from access to a tenant.
Allows Tenant Administrators create a Maintenance window to run imports/updates/reports etc with the knowledge that no tenant users are connected to the Tenant.
Also support presenting a Message similar to the Autodesk Maintenance window
Ability to select all Active Accounts and set to Locked Out status
6 Comments
I like and support this idea....but for a different purpose.
At my company a large number of employees are actually contractors. Our company policy is that contractors can only access business systems during busness hours. With 360 they would have access at all hours.
jared.sund
Status changed to: Accepted
John, interesting idea. Could you provide a use case or two on some administrative tasks where you'd want to lock all users out of the system?
jared.sund
john.stewart
Typically use case is related to new and modifying scripts and not wanting a user to execute the script before it is fully implemented.
I suspect the best practise around this would be cloning a workspace and the scripts in order to fully test the new enhancements and then cutting and pasting the new script into the production workspace.
In place script modification can be dangerous, so I was thinking of locking out all normal users while this is happening.
John
jared.sund
aaron.tw
Status changed to: Archived
