I was experimenting with adding items to the Project Management tab and having added a start date, I moved to adding finish dates. It would enhance the usability, reduce errors and save time if the calendar interface for the finish date started with the start date (or at least the month of the start date) so you can then pick from there. It isn't a problem if the start date is today or in the near future, but if the start date is not for a couple of months, then it would just save having to click through ahead a month or 2,3 4 etc from the calendar which currently comes up with today's date as default.
There is a validation check to stop you being able to save a task as ending before it has begun, but obviously that then takes more time to correct, which could have been avoided if the calendar steered things this way to start with.
Thanks!
Fiona
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
