Just a quick observation and suggestion... so it seems that in Security the "Workflow" permission allows you to see the "Workflow Actions" tab but you need the "Associated Workflow" permission to see the "Workflow" tab.
Also, it's confusing that there are two "Current State" columns available to show in a workspace view. At least in Reports it gives you the option to also show the group that they're coming from, although then you have to export that so that's a bit cumbersome to turn that off and on.
I guess I don't really have a suggestion at this point, but it is something that should be cleaned up.
Thanks for listening!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
