Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Provide control value for image width
3 REPLIES 3
Bill.Bogan
355 Views, 3 Replies
We need to control image size in a page display. Adding a width would work as long as you maintain the L:W ratio. See attached.
Tags (2)
Labels (1)
  • UI
3 REPLIES 3
nguyentru
in reply to: Bill.Bogan
Hi Bill,
When you set the Data Type - Image, there's a feature that will expand your image when you click on the image.
Trung Nguyen | PLM Product Management | Autodesk, Inc.
nguyentru
Hi Bill,
First Option
From the example, I use Image for my Data Type.
When I upload the Image and Save.  The image will be displayed according to the parameter.  However, when you click on the image, it will expand to a bigger size.
Second option to enlarge  the size is to use the iframe method.
1. Set the Data type to Single Line Text.
2. Go to the comupted field and write a simple command script to allow the image to be display.
    '<iframe width="720" height="480" frameborder="0" scrolling="no" marginheight="0" marginwidth="0" src="http://www.autodeskplm360.com/"></iframe>'
Here you can set the width and height of the iframe.
I hope these suggestions help address your need.
Trung
nguyentru
