We have revision controlled workflow for the DCO workspace. On occasions, I make minor changes to a document after the change order has been accepted (not everyone in my company has spelling, grammar and formatting skills). These changes are minor changes that do not affect the content of the document. I usually find these types of errors when I distribute the document. The next change order created for the document does not "see" the document I changed after the DCO has been accepted, it links only to the document attached to the previous change order - even though you can open my document and can see the document history when clicking the history icon. It makes more sense for the next change order to "see" the last document attached rather than just the document linked to the previous change order.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
