It would be really neat to be able to create a field in Item Details (poss elsewhere too ?) that would autofill with comments from the workflow. For example, when taking a delivery, the user clicks on the 'Accept delivery' transition and has to submit a comment as to where the delivered item is. If this could be a field that was configurable to use a picklist AND then write that same info to a field of the same name in Item Details, it would mean the recipient only has to enter the data once, but it is then visible in Item Details should someone else be calling up the record to see where the item is currently located.
I know that the info in this comments box is used in a couple of places (? in the email triggered by the workflow transition , and in the Workflow tab (which I can't seem to see on this workspace), but at the moment it is not v visible when looking at the record on a separate occasion.
In fact, if you could edit the workflow comments to be separate fields rather than just one box, that would expand this idea further. It reduces the clicks a user has to make to fill in the required info while makingit more obvious which info IS required when moving something to the next state in the workflow.
Hope that makes sense,
Fiona
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
