Presently, I can create a picklist which can link me to an item in another (or the same workspace). But there is no way for me to see that relationship from the other side.
There is some abiltiy to do this using the BoM and Relationships. But BoM is a very specific relationship model, and Relationships are too generic.
I would like the ability to add a field type on the "linked" object that references the linking object. The field could be read-only, as I mostly want it for reporting.
For instance, if I have an "Inspection" that has a field "Inspected Item" that references an "Item", I'd like to put a "inspections" field on the "Item" workspace that shows me all the inspections. This item has been included in.
Eventually, I can see this being enhance to support:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
