We are trying to bulk import a new field to bring in all of the data for that field.
We have matched on product number and are bringing in the new dats, but it is giving us an error that the item is "Not in the initial workflow state".
How do we resolve this issue?
Solved by broepke. Go to Solution.
I'm going a little bit from memory here so you might want to test on a simple workspace just in case... (I'm not sure of your setup of course).
But if I remember right, this is a warning that can be "ignored" by changing an import setting. Here you can see before it's set the ID is "red" highlighted and you can't go forward.
However, after changing this setting it turns to a "yellow" color and into a warning state, allowing you to go forward.
