Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
"Add" button does not show in attachement tab?
10 REPLIES 10
Message 1 of 11
fxding
602 Views, 10 Replies
I have been granted with add/edit/delete attachments permissions, but on the [WS] attachment tab the "Add' button does not appear. Any thought? (I have done the same for other [WS] w/o problems.
-Frank
10 REPLIES 10
Message 2 of 11
JohnCHill
in reply to: fxding
Hi Frank,
On the attachments tab, move your mouse to the right of the tab and you will see a drop down Menu to "Upload Attachment".
Please let me know if this helps you.
John
John Hill
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 11
fxding
in reply to: JohnCHill
John,
I cannot locate the "upload attachment" menu. The only option is thru "Add" button for my other [WS].
-Frank
Message 4 of 11
michelle.stone
in reply to: fxding
Frank - could you share what permissions the workspace has?  As long as you have these base permissions, you should have the ability to add files.
If you removed 'add attachements' the button goes away and you need view attachments to see the tab. Thanks!
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
Autodesk, Inc.
Message 5 of 11
broepke
in reply to: michelle.stone
It could also be that you're locked by workflow or a revision.  Make sure that there isn't any other reason it could be locked (also checking to make sure you can edit other things in the workspace is a pretty clear indicator)
Brian Roepke
Director, Analytics & Insights
Message 6 of 11
fxding
Michelle,
I have all the permissions for the attachement.
-Frank
Message 7 of 11
fxding
in reply to: broepke
Brian,
I can update fileds in the detail tab. The [WS] is a basic one with workflow. On the [WS] setup page, it shows a msg: To Do: Upload a workflow. Is this missing workflow that could cause the problem?
-Frank
Message 8 of 11
broepke
in reply to: fxding
I can't remember off hand but yes - it could be locked (especially if you've created items before you added a workflow - these would be locked.
So - add a workflow to that workspace and you'll probably be okay
OR
Add the permission (temporarily) called "Admin override workflow locks" to allow you to edit the workspace records that are locked by the WF (or lack)
Brian Roepke
Message 9 of 11
fxding
Brian,
You nailed it. Thanks!
-Frank
Message 10 of 11
michelle.stone
in reply to: fxding
And confirmed - I created a new workspace with workflow w/o uploading a workflow and low and behold, no 'add' button on the attachments tab.
Michelle Stone
Autodesk, Inc.
Message 11 of 11
broepke
in reply to: fxding
Great news frank!
Those items you added before hand will be "orphaned" from the workflow - i would suggest a couple things..
  1. Add a workflow - even if it's a VERY simple one with just two basic states.  This will ensure that the items all are in a state that will survive and be ready for real workflow later.
  2. If you have created some items - I would suggest you purge them out and create new ones (after the workflowhave been created).  If you need to export and reimport to get them back that works too.
Hope this helps!
Brian Roepke
