Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Workflow with colors
2 REPLIES 2
tray1
409 Views, 2 Replies
I would like a field which is a coloured tile, the colour of the tile changes depending on the workflow state the item is at in the workflow.
I think this is a computed field. I have tried to copy some code I have seen and change it. This is the code I am trying but it errors. I see from the scripting page that descriptor.workflowState should give me the current state of a workflow. that is where I get stuck. I can't sucessfullt use descriptor.workflowState and I don't know if there is a better value I can use to compare against.
This is what I have so far......
Any pointers?
VAR STATE = descriptor.workflowState;
(CASE WHEN (STATE = DOCUMENT_CREATED) THEN '<span style="text-align:center; line-height:30px; color:yellow; background:yellow; width:50px; float:left; height:25px;">YELLOW</span>' WHEN (STATE = INSTALLATION_ARRANGED) THEN '<span style="text-align:center; line-height:30px; color:cyan; background:cyan; width:50px; float:left; height:25px;">CYAN</span>' WHEN (STATE = INSTALL_STARTED) THEN '<span style="text-align:center; line-height:30px; color:red; background:red; width:50px; float:left; height:25px;">RED</span>' WHEN (STATE = INSTALL_STARTED_ERRORS ) THEN '<span style="text-align:center; line-height:30px; color:red; background:red; width:50px; float:left; height:25px;">RED</span>' WHEN (STATE = INSTALL_COMPLETE) THEN '<span style="text-align:center; line-height:30px; color:GREEN; background:GREEN; width:50px; float:left; height:25px;">GREEN</span>' WHEN (STATE = SIGN_OFF) THEN '<span style="text-align:center; line-height:30px; color:blue; background:blue; width:50px; float:left; height:25px;">BLUE</span>' ELSE '<span style="background:white; color:white; width:50px; float:left; height:25px;">WHITE</span>' END )
2 REPLIES 2
tray1
in reply to: tray1
OK so now from another post http://forums.autodesk.com/t5/Autodesk-PLM-360/Workflow-State/m-p/4299260/highlight/true#M1714 I read computed fields only support SQL and HTML not Javascript
So do I create a script that finds descriptor.workflowState then put that value as a field in the item. then compare that field with my case from above?
jpiggee
in reply to: tray1
Hi Tim,
Yes, you would have to pull the value over from the workflow to the item tab (hidden / admin section would work great for this) them you could use this field in your computed filed to report on.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
