Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Workflow action scripts error
3 REPLIES 3
491 Views, 3 Replies
I seem to be having some problems when trying to run an action script on a workflow transition. The script works fine if I use it in the 'edit' behaviour instead.
Is there some system issue stopping workflow transition scripts from running?
David.
3 REPLIES 3
images attached
jpiggee
Havent seen an issue with action scripts in the workflow. What is the error message that is generated and what does the script do?
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
in reply to: jpiggee
Hi Joe,
I have been getting some support from Andrew Shaw at Autodesk support on this. It's being caused by a bug. The PLM 360 development team are investigating.
David.
