Hi
I'm trying to configure the connection between Vault 2013 and PLM 360.
I'm able to choose the workspace but not the lifecycle state (Message: "No valid transitions found")
First I thought I was not defining properly my new worskpace but when using the default Items & BOM happens the same.
Any idea?
Thanks in advance
Daniel Garcia
Daniel,
The lifecycle states required for the Vault Integration are required to meet very specific requirements. You can see the requirements in the help file (you can open the help file from the Sync tool). In general you need to end up with something like the area highlighted in Yellow in the image below:
The general rules are as follows:
Also note that since Vault is responsible for the revisioning of its own items, you do not need a Revisioning workspace in PLM 360 for the Vault data.
Hi Hagay
Thanks for the detailed explanation but I cannot find anywhere how to edit the lifecycle.
If there's an explanation in some place I'd appreciate that you send me a link.
thanks
Daniel
Daniel,
you can find information about the Lifecycle editor in the Wikihelp:
http://wikihelp.autodesk.com/PLM_360/enu/Help/Help/0079-Lifecycl79/0080-PLM_Impl80
You can find the Lifecycle editor in PLM 360 under Administration-->Setup-->General-->Lifecycle Editor
If you hover over the edge of a box, especially near where another arrow is already connected to the box, you will see a semi-circle pop up. Click and drag from there.
Hi
I was able to edit the lifecycles and I have created one like the one you send me (see attached picture). It is associated with a new revisioning workspace called New Change Order.
I still have the same problem, configuring the link from Vault doens't show any valid lifecycle.
BTW: No help in my Vault connector
PD: email me private if you like.
regards
Daniel
HI Daniel,
When you say Vault doens't show any valid lifecycle, does it show an Exclaimation on the connection setup? When you click help as shown, does it launch PLM360 Sync help on your browser?
The possible cause of the issue is that the user you use to connect to PLM360 does not have enough permisson to access teh Life Cycle Phases. I would suggest to add this user to the admin group and then try again
Boris
Hi Daniel,
On the Help Button not able to bring up the PLM360 Sync help menu issue, can yo try the following:
1) Check if the following directory exists or not. If not, please create it
C:\ProgramData\Autodesk\Vault 2013\Extensions\
2) Place attached content under C:\ProgramData\Autodesk\Vault 2013\Extensions\
using extract to "Autodesk.Plm.VaultSync.ConfigExtension\" and
3) PLace help.zip under C:\ProgramData\Autodesk\Vault 2013\Extensions\Autodesk.Plm.VaultSync.ConfigExtension\
using extract to "Help\" and
see if you can view the help file or not after unzipping the content. have been looking at the vault sync setup and could not reproduce the problem/symptom you are experiencing. On the Life Cycle Phase transition: "Eng Revise" do you have the check boxes Increment Version and Increment Release checked?
Boris
HI Daniel,
On the two LCP Transitions,
1) To Eng-Release - Make sure No check boxes are NOT checked for Obsolete, Increment Version and Invrement Release.
1) To Obsolete - Make sure check box is checked for Obsolete,
Increment Version and Invrement Release are not checekd.
Boris
Product Support
Just to close the loop for the benefit of the community, the problem was resolved by matching the LC map to the following image. Note that the Names of the states and transitions are not important, but the designations (the check marks) are. All of these transitions are mandatory. For additional information please see the help file for the sync tool
