PLM 360 General
Active Contributor
ForrestJudd
Message 1 of 6 (261 Views)
Accepted Solution
Using Picklists in Computed Fields
261 Views, 5 Replies
10-12-2012 02:56 PM
I've a question about comparing against picklist fields in computed fields.
The TLDR version: It appears I can get the *index* of a picklist field (that uses a user defined picklist) for use in a computed field. Can I get the picklist field's *value* instead?
Here's the context:
In the default tenant workspaces there are several instances where a field's background color is changed depending on other fields. This is done using a CASE statement, like so:
(CASE
       WHEN (NEXT is null) THEN
                [do something here]
What if we want to evaluate multiple conditions as part of the CASE statement? That's pretty straightforward, we can just add in an AND keyword and the additional condition, like so:
(CASE
      WHEN (NEXT is null AND [additional condition]) THEN
           [do something here]
But what if the condition statement wants to check against the value of a picklist? What we finally puzzled out is that the 'value' of a picklist field actually reports as an integer value. This value appears to indicate the index of the selected value.
The index appears to be granted in the order the value was added to the picklist, not the currently sorted order. What we were specifically working on is the suppliers workspace, which has a field called CYCLE_MONTHS. The first value in the list, '00' is index 5. The second value, '12' is index 3. This was consistent in two different tenants.  The default picklist has 10 total values. When I added an 11th value, its index became 11.
I'm confident I can use this for computed fields, but.... what if the picklist changes? Adding values would be no problem. But what about when values are removed? After a bit more testing, it appears that the indexes *do not* change - at least not immediately.  As an example, I removed the value 18 (with index 1) from the cycle_months picklist. It *did not* change the index of value '00' (index 5).
Ok, all that being said...is there a way I can directly access the *value* of the picklist with a computed field? I'd really rather check against what I expect the field will show, not its index. I'm afraid that the index might change over time, while I would expect its value to be constant.
Active Contributor
ForrestJudd
Message 2 of 6 (257 Views)
Re: Using Picklists in Computed Fields
10-12-2012 03:10 PM in reply to: ForrestJudd
One thought I just had is if I could use a SELECT statement in the computed field to derive the actual value based on the index, but I don't know:
  • if SELECT is valid in a computed field
  • What columns would be used for the select statement
  • What the table name would be
Board Manager
broepke
Message 3 of 6 (245 Views)
10-14-2012 08:49 AM in reply to: ForrestJudd
Hi there,
In a computed field you can only get access to the index.  You are correct that these don't change so with a little investigation you can reverse the indexes back out to the values you need.
If you need something more complex you should use scripting.  It has access to the values as well as a much more elaborate set of functions that can be used.
Brian Roepke
Director of PLM & PDM
Autodesk, Inc.
Active Contributor
ForrestJudd
Message 4 of 6 (233 Views)
10-15-2012 08:45 AM in reply to: ForrestJudd
Thanks for the quick feedback Brian.  Is there a good reference somewhere for syntax and what we can access via computed fields?  I'm an experienced programmer, but I had to do a fair amount trial and error to get the syntax of the logic statements to work out in this case.
Board Manager
broepke
Message 5 of 6 (227 Views)
10-15-2012 09:20 AM in reply to: ForrestJudd
There isn't an exhaustive list of what's supported - You can basically say it's more limited in it's syntax than rich.  Meant to do simple calculations for the most part (like LENGTH * WIDTH).  But some additional things are supported.  Here is an article that someone on the team came up with that might help
http://wikihelp.autodesk.com/PLM_360/enu/Community/Tips/Configuring_Fields/Computed_Fields%3a_Small_...
Brian Roepke
Autodesk, Inc.
Member
Tony.Gonzalez
Message 6 of 6 (49 Views)
04-29-2014 11:48 AM in reply to: ForrestJudd
I am experiencing the same and given the date of this post I am assuming there is no fix or workaround to this using computed fields.
You are not logged in.
Announcements
Ask the Community
