In the 'Sequencer' workspace which is provided with the standard tennant the 'Seq ID' field uses the value 'DMSID' in the computed field formula to display the dmsid of the item. However I do not seem to be able to use it myself. Nor can I clone the 'Seq ID' field.
Is there something that I'm doing wrong?
David.
Hi David,
We're blocking the system prop (DMSID) from being used in computed fields now. However, checking with the guy that wrote the sequencer that field isn't really needed. It's essentially just there to make it easier for new users to "see" the DMSID.
You can still call the DMSID via scripting and it will give you the same result.
print(dmsID);
http://wikihelp.autodesk.com/PLM_360/enu/Help/Help/0091-Develope91/0092-Server-S92/0099-Scriptin99
