Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Usind a Date in a Computed Field Without the Timestamp
1 REPLY 1
548 Views, 1 Reply
I'm using a computed feild to compare a field called DUE_DATE to today's date. My problem is that DUE_DATE is formatted YYYY-MM-DD 00:00:00.000. When check to see if DUE_DATE is equal to GetDate() (i.e. today's date) the value of GetDate() is YYYY-MM-DD 11:13:28.943 so my camparsion is always false even if they are the same day as the exact time is different.
Is there a way to ingnore the timestamp for my comparision?
1 REPLY 1
bastien.mazeran
You could use CONVERT(DATE,GETDATE()) command to only return the date.
And for a date other than now, you could use syntax below:
CONVERT(DATE,'2013-08-06 11:13:28.943')
I hope this will help you compare the two dates.
Bastien Mazeran
Technical Support Specialist
