is there any way to pass 'seach' parameters via a PLM 360 URL. For example, can I add something like '&keyword=test' to the end of the standard search url to get it to run a search for something with 'test' in it?
Also is there any way to generate an URL to workspace item using one of the item parameters instead of the dmsID. For example;
https://<NAME>.autodeskplm360.net/workspace#workspaceid=77&tab=itemdetails&NUMBER=12345
David
Solved by gasevsm. Go to Solution.
Hello David,
There is no propcess in place for using the url to pass search parameters. Is there a reason you don't want to just use the search tool that is in place?
Hi John,
Thanks for the quick reply. All I'm trying to do here is autopopulate some fields on a form in a different way for different users. I don't want to create the item. Is this not standard functionality for any web application? The API won't suit us here I think.
Should I put this into the IdeaStation?
David.
Hi Martin,
The issue is this. I'm creating a workspace to allow sales managers to submit RFCQs (Request For Customisation Quotation) to the engineering department. When the sales manager goes to create an RFCQ he does so by clicking on a shortcut that brings hin directly to the form for a new RFCQ in PLM;
https://<NAME>.autodeskplm360.net/createItem.do?dmsID=&workspaceID=77
The sales managers are required to fill in fields on the form such as 'Customer', 'Sales Region', 'Industry Type' etc. However some of these fields (like 'Sales Region' will always be the same for each sales manager. So I want to give them a shortcut that links them a new RFCQ where the 'Sales Region' field is already filled in to match their personal requirement. Some other fields like 'Customer' should default to the largest customer for that region.
The functionality allows us to embed 'smart' hyperlinks from within other enterprise systems that open up new forms in PLM that are pre-populated with the correct information. We already use this to great effect with SAP and some other web-based applications we use.
David.
