I started a trial of PLM 360 but I seem to be missing all the default apps? Is this a limitation of the trial?
Cheers
Solved by michelle.stone. Go to Solution.
There are 4 different 'flavors' of the trial - Program Managment, Engineering Management, Quality Management and Facilities Management. The apps available are specific to those areas.
There are great guides for each type on the Wiki: http://wikihelp.autodesk.com/PLM_360/enu/Community/wAutodesk_PLM_360_App_Guides
Take a look at the Change Management one.
Hope that helps!
Michelle
