Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
The validator is not supported
0 REPLIES 0
Message 1 of 1
311 Views, 0 Replies
I am now encountering the same problem that "sdibben" did. (http://forums.autodesk.com/t5/Autodesk-PLM-360/Uploading-items-Error/m-p/3746271/highlight/true#M109...
And it includes also the field "Integer".
"The validator "Integer" of field Art nr is not supported."
"The validator "Money" of field Pris (SEK) is not supported."
I have checked the dataposts. They should be ok. I have added an UOM of SEK.
I don't think it is an acceptable solution to the problem, suggested in the conversation, that you should have to first change all the fiels to "Single line text", run the import and then have to chenge the filds back to "Money"/"Integer". I have 15 Warnings about this problem and I get "A server-side error has occurred." and am not able to Import my Items.
Does anyone have a new solution?
Ann
0 REPLIES 0
