Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Syntax supported for scripting
3 REPLIES 3
ptrujillo
451 Views, 3 Replies
I am new to PLM360 and would like to build my scripts in libraries and classes etc..
I would like to know if there is a published syntax (java) supported in PLM360?
Thank you,
3 REPLIES 3
broepke
in reply to: ptrujillo
Take a look at the help file.  There is a full set of examples and information about functions and objects, etc...  as a good starting point the language is based on JavaScript.
http://help.autodesk.com/view/PLM/ENU/?guid=GUID-1EFE1FAC-1CFF-4F2E-987F-9801DF590E57
Also - a great way to get going is to run a script through the advanced debugger we just released.  If you've done any coding you should feel right at home with this.
http://help.autodesk.com/view/PLM/ENU/?guid=GUID-764824AA-A429-4995-ACC0-64EEFB033507
Brian Roepke
Director, Analytics & Insights
broepke
One more thing - Scripting is for server side control of items and workflows.  Typical use case is to execute logic when workflows are performed in the form of conditions, validations and actions.
If you want pure API access to the data in a CRUD fasion you can use the REST API.  With REST you can use just about any Programming Language:
See Here: http://help.autodesk.com/view/PLM/ENU/?guid=GUID-3825A309-3130-4F2D-82F1-68D189D03B02
Brian Roepke
ptrujillo
in reply to: broepke
This is exactly what I was looking for. A debugger is nice. Thank you
