Is there a storage limit to how much data you can generate and keep on the service?
Solved by JohnCHill. Go to Solution.
Hi Chad,
Welcome to the PLM 360 Forum.
2GB per PLM 360 user is the soft stop. Based on historical data this should be enough for any customer but can be revisited if it is found there is a need for more disk space.
Hi Jonas,
What is the scenario where you think you will need to upgrade to over the 2GB limit?
John
Hi Jonas,
Please contact your sales rep. and they can go over the best options with you for this circumstance.
John
